Skip to main content
Your basket
Monthly payment
  • every month for months, then
  • months contract
  • no annual contract
Monthly payment total
£xx
One-off payment
One-off payment total
£xx
Included with your package
Summary
Monthly payment
    From
    From
    One-off payments
    Reward Card included
    to say thanks for signing up
    Amazon gift card
    cashback icon
    Today's payment
    From
    From
    Today's payment
    About Plusnet's Broadband Firewall
    Discover how Plusnet Broadband Firewall works to protect your broadband connection and the devices using it.
    Broadband firewall FAQs
    It's an easy way to protect your broadband connection and the computers using it. If you've got it on, it'll block unwanted connections from the web and protect you against hackers and other Internet nasties.
    Firewalls will deal with most potential problems, but they can't solve everything. So we recommend you use it with anti-virus and anti-spam software e.g. Plusnet Protect to keep yourself as secure as possible.
    You won't have to pay a thing for it. We want to do everything we can to keep you safe online.
    Our Broadband Firewall aims to stop unwanted Internet traffic before it gets anywhere near the software on your computer. Most PCs and laptops come with a firewall already up and running. We recommend leaving it active. Have a look at the manufacturer's instructions for more info.
    Yes, and it's pretty simple.
    1. Go to the Member Centre
    2. Click on Connection settings
    3. Click Broadband Firewall to update your settings
    From there you can choose the setting you'd like. It's set to low by default.
    There are three basic settings. Here's what each one does.
    Off
    This turns off your firewall completely. All Internet traffic will be able to reach your network and devices. We only recommend this one if you have to turn it off to test a connection problem.
    Low
    On this setting your firewall will give you good protection. It'll stop most malicious traffic while still letting more normal Internet traffic through. You'll need to use this if you're using VPN software because it won't work if your firewall's set to High.
    If Broadband Firewall has been set on LOW, this is to protect your router from inbound traffic on the following Internet PORTS:
    53, 111, 135, 137, 138, 139, 445, 515, 1080, 1433, 3128, 3306, 6000
    These ports are generally not used by home or small-business users and your connection is made safer by having them blocked before they reach you.
    High
    This setting blocks all unauthorised incoming traffic, so no external source will be able to connect to your network or your devices. Software updates and administrative traffic for Plusnet-provided routers will still be allowed.
    It will stop some things working, such as certain apps, VPN software or active FTP sessions. So if you need to use one of those, switch your firewall back to Low.
    Advanced settings won't give you more protection than the basic ones, but they're handy if you want to have more control over what's blocked and what isn't.
    If you're not sure which is best for your connection, we recommend sticking to the basic settings. But here are the advanced options available.
    Read more Read less
    Block common ports
    This setting blocks all traffic to common ports below 1024. Those are normally used for things like emailing.
    Block common ports except HTTP and HTTPS
    This setting blocks all traffic to common ports below 1024, except for ports 80 and 443. That means you can block incoming traffic but also run a web server. You won't need this if you're just browsing sites online.
    Block common ports except SMTP
    This setting blocks all traffic to common ports below 1024, except for port 25. That means you can block incoming traffic but your emails will get through. You won't need this if you're just sending and receiving email using a desktop email application.
    Block common ports except HTTP, HTTPS and SMTP
    This setting blocks all traffic to common ports below 1024, except for ports 25, 80 and 443. That means you can block incoming traffic but still run a web server and your emails will also get through. You won't need this if you're just browsing sites online or sending and receiving email using a desktop email application.
    Our firewall settings aren't fully customisable. But if you want to set up stricter rules, you can run your own firewall as well.
    The change will be made straight away on our network. But you'll need to restart your router to see it.
    Sometimes, some programs and software don't work properly when you change your firewall settings. If that happens, try changing to the Low option in Basic Settings.
    Or try lowering your firewall settings in stages, restarting your broadband connection every time. If you've turned your firewall off completely and you're still having trouble, then the problem might not be to do with your firewall.
    If that doesn't work, get in touch with your software provider.
    This might be because of the settings in your file transfer software. This type of software gets data in two different ways, Passive or Active. If possible, switch the settings to Passive, instead of Active. If you need to keep using Active, switch your broadband firewall to Low.
    A VPN is a secure connection into a corporate or business network. VPN connections might be blocked by the Broadband Firewall, but it'll depend which type you're using. If your VPN is blocked, reset your firewall to Low and then restart your router.
    Was this article helpful?
    More ways to get help
    Plusnet community
    Talk to our community
    Contact our team
    Or call 0330 1239 123
    Sign Language service
    Contact us using British Sign Language
    My Account
    Sign into Broadband
