Skip to main content
Your basket
Summary
Monthly payment
From
From
One-off payments
Reward Card included
to say thanks for signing up
Amazon gift card
cashback icon
Today's payment
Monthly payment
  • months contract
  • no annual contract
Monthly payment total
£xx
One-off payment
One-off payment total
£xx
Included with your package
Summary
Monthly payment
From
From
One-off payments
Amazon gift card
cashback icon
Today's payment
Today's payment
How to connect to broadband using your own router
The settings you need to connect to Plusnet broadband using your own router.
If you've got a router of your own (one that we haven't sent you), read on for the settings to use to get connected. It'll need to be a router that's compatible with our broadband network. So you might not be able to use a router if it came from your old service provider.
If you're using a router from us you shouldn't need to change any settings. It's ready to start using. But if you're having trouble setting it up, try our router guides or videos. Or take a look at the instructions that came with it.
Connection setting FAQs
If you've got standard broadband (not fibre), here are the settings you need. Some of these terms can vary from router to router, but these are the most commonly used.
It asks for: Use:
Broadband username or login name yourusername
@plusdsl.net
Connection type or encapsulation 'PPPoA' or 'PPP over ATM'
Password The password you use to log in to My Account
Virtual Path Identifier (VPI) 0
Virtual Channel Identifier (VCI) 38
Multiplexing method 'VC Based' or 'VCMUX' or 'VC-Multiplexing'
Some routers might ask for other settings that aren't in our table. You should be able to stick with the default settings or leave them blank.
If you've been a Plusnet customer for a very long time then you may need to use something else after the '@' in the username. If you're unsure have a look at your connection settings in My Account.
If you've got fibre broadband, here are the settings you need. Some of these terms can vary from router to router, but these are the most commonly used.
It asks for: Use:
@plusdsl.net
Connection type or encapsulation PPPoE Always On
Password The password you use to log in to the My Account
VLAN Active
VLAN ID (802.1q) 101
VLAN ID (802.1p) 0
Not all routers will ask for all these settings, so don't worry if you can't find some of them. Just make sure the settings it does ask for match the ones above.
If your fibre router is connected to a BT Openreach modem, here are the settings you'll need. Some of these terms can vary from router to router, but these are the most commonly used.
It asks for: Use:
@plusdsl.net
If you’re still having trouble getting connected, try our troubleshooting guide. If this doesn’t resolve the problem, please report it to us.
Was this article helpful?
More ways to get help
Plusnet community
Talk to our community
Contact our team
Or call 0330 1239 123
Sign Language service
Contact us using British Sign Language
My Account
Sign into Broadband
